1 - 8 of
81
I might be pairing transient analysis with a wrong optimization response.
Prakash,
Optistruct uses SIMP method for optimization. SIMP method generally can be used paired with Transient Response. That leaves me assume that transient response optimization is physically possible, but is not supported in Optistruct.
Is that because of a problem with the algorithm or that transient response is simply omitted from optimization?
Hi,
Can you share the entire .out file?
