🎉Community Raffle - Win $25
Join and Win
How can we use vehicle mass in altair activate while modelling, say a light weight car.
User: "Pushkar Kumar"
Altair Community Member
Updated by Pushkar Kumar
1 - 3 of 31
    User: "RoKet"
    Altair Employee
    Updated by RoKet
    Can you please explain your question a little bit more? The model on the slide uses a variable 'vehicleMass' as vehicle mass. This variable is probably defined in the model or diagram context. But that's not all, right?
    OP
    Yes I defined the variable in the model in codes, but how to keep that in diagram context as shown in the block diagram, where can I find that in activate software?
    User: "RoKet"
    Altair Employee
    Updated by RoKet
    Variables that are used in a block or component are defined either in initialization or diagram context.
    Both are available by the two icons in Home ribbon. For more details, see Context and Initialization.
