How can we use vehicle mass in altair activate while modelling, say a light weight car.
Pushkar Kumar
Pushkar Kumar Altair Community Member
edited July 2023 in Community Q&A
Welcome!
Answers
  • RoKet
    RoKet
    Altair Employee
    edited July 2023
    Can you please explain your question a little bit more? The model on the slide uses a variable 'vehicleMass' as vehicle mass. This variable is probably defined in the model or diagram context. But that's not all, right?
  • Pushkar Kumar
    edited July 2023
    Yes I defined the variable in the model in codes, but how to keep that in diagram context as shown in the block diagram, where can I find that in activate software?
  • RoKet
    RoKet
    Altair Employee
    edited July 2023
    Variables that are used in a block or component are defined either in initialization or diagram context.
    Both are available by the two icons in Home ribbon. For more details, see Context and Initialization.
Welcome!
Welcome!
