Hello, Thanks for reply. Actually I am running a macro which will extract free edges automatically and takes picture od complete hypermesh window. It is capturing image but The gui for edges is not showing. In backend macro running. I want picture along with edges window activation... Tool - > edges... This should highlight while taking pictures......
i believe the screenshot goes only with the contents of the graphical area.
can you take a screenshot (manually) of what you want in the end? not sure if I got it. do you waant the panel also?
Exactly right... I want panel mainly.. Graphical area I am OK but panel mainly I need it with. Panel should change as per macro....i believe the screenshot goes only with the contents of the graphical area.
You could get the whole area (might be too much), using the HDW command: CaptureDesktop
hwi OpenStack
hwi GetSessionHandle sess
sess CaptureDesktop png C:/temp mypicture.png
hwi CloseStack
can you detail better (with some pictures) what are you trying to accomplish here?
