How to change T-connections and free edges in gui by using tcl or HM macros?
Sridhar Bagathi_22035
Sridhar Bagathi_22035 Altair Community Member
edited June 2021 in Community Q&A
I want to capture pic while conducting both... I tried script but it is not changing... Can some body help me
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    can you detail better (with some pictures) what are you trying to accomplish here?
  • Sridhar Bagathi_22035
    edited June 2021
    Hello, Thanks for reply. Actually I am running a macro which will extract free edges automatically and takes picture od complete hypermesh window. It is capturing image but The gui for edges is not showing. In backend macro running. I want picture along with edges window activation... Tool - > edges... This should highlight while taking pictures......
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    i believe the screenshot goes only with the contents of the graphical area.
    can you take a screenshot (manually) of what you want in the end? not sure if I got it. do you waant the panel also?
    edited June 2021
    Exactly right... I want panel mainly.. Graphical area I am OK but panel mainly I need it with. Panel should change as per macro....
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    You could get the whole area (might be too much), using the HDW command: CaptureDesktop
    hwi OpenStack
    hwi GetSessionHandle sess
    sess CaptureDesktop png C:/temp mypicture.png
    hwi CloseStack
    edited June 2021
    Thank you very much for valuable help. One more query..... When I read macro pushpanel items are not showing as active in hypermesh window while capturing pic... Means I am trying to capture free edge picture along with Tool->edges window active in panel and in desktop... So that we can show clearly we are in edge panel....
Welcome!
Welcome!
