In Proman, I am trying to do a simple time changing simulation and exporting the pattern from a arbitrary prediction plane that is defined in Wallman. As it can be seen on the images, I can only see changes in the simulation of the points on the floor (the prediction rectangle defined in Proman) and not on the vertical prediction plane that is defined in Wallman. Is there something I must enable in order to do that?
I am using standard ray tracing, the database is not preprocess.
The results for other times than 0 for the random prediction plane are also not in the ASCII file.
