Hi DataWatch community,
I am trying to have a batch file that will help me automate all the prj files in my stand alone desktop. When I run the batch file, it opens the Monarch 14 and just stops there.
I was able to export the result into the text file by specifying the file in the /exp command line option in the previous version of monarch 9.
When I was searching this forum on this issue, I found people say that "Since 11.6 the batch commands simply don't work unless you buy a $25,000 license for a desktop version with automation support."
Is it really TRUE??
Thank you for all your help!
Anu
