Problems with ERROR # 1000
Hello,
I have this error while trying to solve a modal analysis. I checked that the material and property were correctly assigned then i tried by deleting all the tria3 element but i still get the error
can someone please help me or guide me to a solution?
Thank you in advance
Hi,
thank you for your reply. You can find the file in this link case it exceeded the max size.
https://drive.google.com/open?id=1cl7QCgYuIQLSbQ-ootwTJk3JW4MYwaqS
I really don't get why. can't wait for your help
Hi,
I assigned the property to BARRE_PEDALE_3D however it didn't go through
I also checked the node dependency, and i corrected the one i got. now there is 0
i'm new to hypermesh. the way i check the node/dependency is by going to Mesh->check->node->dependency i selected all the element.
here's the file modified
https://drive.google.com/open?id=1URK67J4H7ABRkX8Kvlcx2ehhQw83OYmr
thank you
Hello,
Thank you for your reply. I'm using the Hypermesh 2017.2
Here's the .out file
Thank you
Please try running attached fem file.Since structure is not connnected and without boundary condition, first 12 modes would be rigid for free free modal analysis.
C
Thank you, here's the file .fem
In this file..Component name with seat is repeated 14 times..Just delete all component with name seat.
Attached is the updated fem file.If you are not comfortable with HyperMesh interface then you could explore Basic FEA or SolidThinking Inspire for Staic & Modal Analysis.
Refer out file for the error and warning.Please refer attached video.
Could you also attach the fem file to take a quick look?
