Hello,
I am running a topology optimisation using Optistruct. The results I am getting for a standard min. compliance, constrained volume fraction run without any manufacturing constraints are invalid. The simulation runs but the results do not show any clear structural members but mostly very low density material.
However, when I use minimum member size control, extrusion constraints and change the discrete value the results achieved are valid (show structural members).
Is there a way to chance the minimum convergence parameters to encourage the solution to find a valid structure for on optimisation without manufacturing constraints.
Thank you in advance
