how to know the SSTYPE of the slave ids in a contact using tcl ?
I want to know if the slave of a contact (group) are exempted ones or no...
Refer the attached image....once the check box is clicked the transpose of SSID becomes the slave...
but in TCL for the commnad
hm_getvalue groups id=6 dataname=slaveentityids
we still get the set which we have selected ... and not its transpose
so.. i need to know how to get the slave ids
one way is the SSTYPE given in image changes from 2 to 6 when check box is ticked .... but i dont know the tcl command to get the SSTYPE value
honestly i don't get what you call transpose, but anyway.
Some datanames are solver independent attibutes and these can be retrieved from the 'datanames' section in the documentation.
Some others are only related to a particular solver, and that seems to be your case.
In these cases, usually what i do is to open the model, lauch this script provided in the installation and run it.
C:\Program Files\Altair\2022.3\hwdesktop\demos\hm\examples\scripts
This script shows what are the attributes used in this entity, and also what are the attribute name.
So to retrieve this particular attribute you can call it using \$attribute_name
In my example, for OptiStruct the attribute name might be \$PSHELL_T
In yours, maybe it will be \$SSTYPE
By transpose I mean
While giving single surface contacts, for selecting slave what we do is select a few components and click the exempt slave parts option given in the image (ExemptSlvPartSet) by this all the other components except the ones selected become slave...
but in TCL for the commnad...
[hm_getvalue groups id=6 dataname=slaveentityids]
Also I am using LsDyna user profile ... could you please help with me with that... i dont have the option of Entity attribute
