🎉Community Raffle - Win $25
Join and Win
Grid IDs
User: "awe901"
Altair Community Member
Updated by awe901
I'm using Hypermesh 2019.
Quick question, using Multiscale Designer and the readme file says that Grid IDs need to start at 1 and move up by 1 incrementally.
Is that basically telling me that I need to go to Tools>Renumber> and then renumber my elements and nodes starting at 1? Or are Grid IDs something else? If so, could someone direct me to that feature on Hypermesh?
1 - 2 of 21
    User: "Adriano Koga_20259"
    New Altair Community Member
    Updated by Adriano Koga_20259
    Hi,
    You are correct. Use Renumber for that.
    this statement is true for 'External Unit Cell' generation, when you want to create your own Unit Cell.
    If you're just using a regular model in co-simulation with MDS, this is not necessary.
    User: "awe901"
    OP
    Updated by awe901
    Hi,
    Thank you very much! Troubleshooting and trying to determine specifically what the problem is.
