🎉Community Raffle - Win $25
Join and Win
Combining Laminate & Solid
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
i would to like to create a static analysis with radioss of a model consisting of a wooden core and several plies at each sides.
It would look like this:
I now know how to create a solid:
import geometry from catia, create mat&property, assign cardimage psolid/pshell
now for the laminate:
laminates seem to be always centered around a surface, is there a way to make them only go into one direction?
can i use the same geometry for the core and the laminate?
if they are in different components, i have to chosse Pcompp as the card image for the laminate geometry property, do i have to combine these two? (the one containing the geometry with the solid, and the one with the laminate geometry)
whats the best way to build a ortotrophic woven composite?
Thanks in advance!
1 - 2 of 21
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    It's a better way to create 2 composite sheets, upper and lower, each has 2 plies
    in this case core should be hexa/penta mesh
    Altair Employee
    OP
    Friends,welcome to our website, you can get cheap mbt shoes here.
    Also you can see kinds of mbt shoes.I believe you can get good
    mbt shoes on our website.
