Combining Laminate & Solid
i would to like to create a static analysis with radioss of a model consisting of a wooden core and several plies at each sides.
It would look like this:
I now know how to create a solid:
import geometry from catia, create mat&property, assign cardimage psolid/pshell
now for the laminate:
laminates seem to be always centered around a surface, is there a way to make them only go into one direction?
can i use the same geometry for the core and the laminate?
if they are in different components, i have to chosse Pcompp as the card image for the laminate geometry property, do i have to combine these two? (the one containing the geometry with the solid, and the one with the laminate geometry)
whats the best way to build a ortotrophic woven composite?
Thanks in advance!
It's a better way to create 2 composite sheets, upper and lower, each has 2 plies
in this case core should be hexa/penta mesh
0 -
