🎉Community Raffle - Win $25
Join and Win
check node coordinates(x,y,z), NodeID and its mother element, ElementID and its nodes
Hi Group,
would anyone give some hints to make it using macro or TCL/TK?
in addtion, I would like to search/find the closest elementID.
Thank in advance for any advices!
Sternchen
1 - 12 of 121
    Sternchen
    There are a number of existing TCL macro scripts in the install directory of HyperMesh ...\hm\scripts organized for each solver. These are the same ones that are activated by the 'Utility' menu in HyperMesh that change for each User Profile that you select. They range from relatively straightforward ones (i.e. dynakey\findfreerigids.tcl) to more complex ones that create their own GUI panels (nastran\tablecomps.tcl).
    There are also some examples from users if you go the 'macro exchange' area on the www.altairhyperworks.com website.
    You may want to start creating a macro by reviewing a series of commands that you perform in HyperMesh that get recorded in your command.cmf file. You can basically use any 'macro' command in TCL, plus all the TCL commands for loops, logic, file management, etc. The main difference is for TCL, you have to remove all the parentheses and commas between data fields. To create a node in TCL, you would enter
    *createnode 1 1 1 0 0 0
    Have a look in the online help for HyperMesh - Reference Guide, Utility Menu and Tcl/Tk, Programming HyperMesh with Tcl/Tk for more info.
    Cheers,
    Eric
    Eric,
    Thanks for your advices regarding the general guideline for using TCL/TK, HM Macro.
    But maybe you have missed the thread title.
    I want to find a *hm_??? command to find a certain node's coordinates(x,y,z) and its belonging element IDs, and so far also the neighbor element IDs...
    The most related command I could find now is:
    hm_getcoordinates
    But it only support points not node.
    I really do not want to dig into the hmlibs & C++ etc... :-)
    Regards!
    To get the coordinates of a node, you can use
    set  CoordX [hm_getentityvalue NODE $n1 'x' 0]set  CoordY [hm_getentityvalue NODE $n1 'y' 0]set  CoordZ [hm_getentityvalue NODE $n1 'z' 0]
    Search for 'Data names' in the online help - the same command can be used to get the node id values for an element in your model.
    To find which elements are attached to a node (there can be many more than 1), use the find command:
    *clearmark nodes 1*clearmark elems 2eval *createmark nodes 1 $n1*findmark nodes 1 1 1 elems 0 2set list_of_elems [hm_getmark elems 2]
    Hope this helps
    Eric
    Eric, you are great! That was exactly I want.
    You just opened the door to me.
    Thanks!
    Hope this helps
    Eric
    Another version could be:
    foreach {CoordX CoordY CoordZ} [join [hm_nodevalue $n1]] {}
    Important is, that hm_nodevalue returns a tcl-list of all 3 coordinates.
    Greetings
    Thomas
    Hi:
    I want to get the nodal positions of the displayed nodes and compare their 'X' positions and get the max and min of those.
    I am a newbie and I am stuck here:
    *createmark nodes 1 'displayed'
    set nodelist [ hm_getmark nodes 1];
    set length [llength nodelist]
    tk_messageBox -message '$length !'
    when I print the $length variable, I expect it to print the # of displayed nodes and it just prints '1'. Can anyone please help me how do I proceed from here
    Thanks much in advance
    Dinesh.M
    Hey Dinesh
    There's a simple solution to your problem. The command llength is expecting to see a list of entries, so it is counting 'nodelist' as 1 item. For it to count the contents of your variable, you need to put a $ in front
    *createmark nodes 1 'displayed'set nodelist [hm_getmark nodes 1]set length [llength $nodelist]puts ' list is $length nodes'
    Good luck,
    Eric
    set nodelist [hm_getmark nodes 1];
    I would continue like this:
    foreach {CoordX CoordY CoordZ} [join [hm_nodevalue [lindex $nodelist 0]]] {}set minX $CoordX; set maxX $CoordX ;# initializationforeach nID $nodelist {    foreach {CoordX CoordY CoordZ} [join [hm_nodevalue $nID]] {}    if {$CoordX < $minX} {set minX $CoordX}    if {$CoordX > $maxX} {set maxX $CoordX}    # do the same for Y and Z if you need it ...}
    puts 'minX = $minX\nmaxX = $maxX'
    If you do not like the more complex 'foreach and hm_nodevalue construct' you can use 'hm_getentityvalue' as shown above.
    Good luck
    thomas
    Is there an alternative to
    to get a list of all the node ids in the model that will run quickly for large meshes?
    QuyNguyenDaiUser: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    What's your goal? Output node-ID & coordinates?
    tinhUser: "tinh"
    Updated by tinh
    Use
    set nodelist [hm_entitylist node]
    It runs faster than *createmark and hm_getmark
    Thanks tinh!
    I had to change it to
     set nodelist [hm_entitylist nodes id]
    but it worked out
