🎉Community Raffle - Win $25
Join and Win
get component name from a line or surface
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hi, there!
how can I get the component name of a line or surface using tcl? is there a hm function that I could use.
example. If I select a surface with its number, how I could get its component name or ID
thanks!
1 - 8 of 81
    Altair Employee
    OP
    Try this:
    *createmark surfaces 1 999
    (where '999' is the id of the surface)
    to get the component id use then:
    hm_getentityvalue surfaces 1 'collector.id' 0
    to get the component name use then:
    hm_getentityvalue surfaces 1 'collector.name' 1
    Regards,
    Stefan
    Stefan Hettel
    Manager HyperWorks Support
    Altair Engineering GmbH
    Calwer Strasse 7
    D-71034 Boeblingen, Germany
    Tel.: +49 (0)7031 6208-46
    Fax : +49 (0)7031 6208-99
    mailto:hettel@altair.de
    Altair Employee
    OP
    Stefan,
    thanks a lot, that was easier than expected
    ~ cesar
    User: "Upadhyay"
    Altair Community Member
    Updated by Upadhyay
    I don' think that this method works anymore. Is there an alternate solution?
    User: "tinh"
    Updated by tinh
    You don't think that, but yet actually it still works
    User: "Upadhyay"
    Updated by Upadhyay
    Hi tinh,
    I tried the following code:
        *createmarkpanel line 1 'Please select the Line on the SAME component';
        set line1 [hm_getmark line 1]
        set compId [hm_getentityvalue lines 1 'by comp id' 0]
        hm_usermessage $compId
    When I run this, it gives 1 as the output which is not the component id. Can you please tell where I am going wrong
    User: "Upadhyay"
    Updated by Upadhyay
     Sorry, the code is :
        set compId [hm_getentityvalue lines 1 'collector.id' 0]
    User: "tinh"
    Updated by tinh
    It should be:
        set compId [hm_getentityvalue lines $line1 'collector.id' 0]
    User: "Upadhyay"
    Updated by Upadhyay
    Hello tinh,
    Sorry for the late reply. Thank you very much. It works great.
