🎉Community Raffle - Win $25
Join and Win
.sta file of any animation file
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
dear sir,
Suppose, i want to get the .sta file of any animation file(say animation 8) so, how can i get this???
1 - 4 of 41
    Altair Employee
    OP
    Hi,
    You can print .sta file for a time interval using Tfreq in /STATE/DT.
    This will print .sta file at a given frequency. But it may not be possible to print for a particular time step or animation.
    Please Note: If you are a commercial customer, you can contact your local support for a script that will help you do the same http://www.altairhyp...ortProduct.aspx
    Altair Employee
    OP
    dear sir,
    Where can i find 'Tfreq in /STATE/DT' option in hyperform?
    Thanks,
    Altair Employee
    OP
    dear sir,
    where can i get Tfreq in /STATE/DT this option
    Altair Employee
    OP
    Hi,
    You have to manually input in the Engine file.
    Open <filename>_0001.rad file and change the frequency shown in the picture.
    default, the start time and Tfreq for /STATE/DT is same which results in only one .sta file.
    change the /STATE/DT such a way that start time is zero and your desired frequency.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-42742100-1424857100_thumb.jp
