dear sir,
Suppose, i want to get the .sta file of any animation file(say animation 8) so, how can i get this???
You can print .sta file for a time interval using Tfreq in /STATE/DT.
This will print .sta file at a given frequency. But it may not be possible to print for a particular time step or animation.
Please Note: If you are a commercial customer, you can contact your local support for a script that will help you do the same @ http://www.altairhyp...ortProduct.aspx
Where can i find 'Tfreq in /STATE/DT' option in hyperform?
Thanks,
dear sir, Suppose, i want to get the .sta file of any animation file(say animation 8) so, how can i get this???
where can i get Tfreq in /STATE/DT this option
You have to manually input in the Engine file.
Open <filename>_0001.rad file and change the frequency shown in the picture.
default, the start time and Tfreq for /STATE/DT is same which results in only one .sta file.
change the /STATE/DT such a way that start time is zero and your desired frequency.
