Host ID without Ethernet Adapter
Hi, i have trouble finding the Host ID because my Laptop does not have a Ethernet Adapter
which Physical adress should i use instead?
IP Config File:
C:\Users\Tim>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-*******
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : fritz.box
Wireless LAN adapter LAN-Verbindung* 1:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 40-A3-CC-29-19-0A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter LAN-Verbindung* 3:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 42-A3-CC-29-19-09
Wireless LAN adapter WLAN:
Connection-specific DNS Suffix . : fritz.box
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 8265
Physical Address. . . . . . . . . : 40-A3-CC-29-19-09
Link-local IPv6 Address . . . . . : **********
IPv4 Address. . . . . . . . . . . : ***********
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, September 24, 2019 10:57:12 AM
Lease Expires . . . . . . . . . . : Friday, October 4, 2019 4:48:23 PM
Default Gateway . . . . . . . . . : ************
DHCP Server . . . . . . . . . . . : ************
DHCPv6 IAID . . . . . . . . . . . : ************
DHCPv6 Client DUID. . . . . . . . : *************
DNS Servers . . . . . . . . . . . : ***************
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth-Netzwerkverbindung:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 40-A3-CC-29-19-0D
Thanks in advance
Hi,
Kindly use the physical address under Wireless LAN adapter WLAN: 40A3CC291909
I also would like to know that as I am using a Microsoft Surface Pro 6 and since that device does not have a LAN port the host ID tool doesn't work out for me.
