Altair RISE
Nominate Yourself Now!
How to use an external excel file for topology optimization in optistruct as an objective?
Hi,
I would like to use Optistruct for topology optimization.
There is no any built-in response which can I use for my custom objective function. Making an equation is also not an option. I have just read, that the cells from given excel files can be used explicitly as a response.
The task is the following:
There are multiple loadcases. I would like to choose 3 from them, and request their Strain Energy Densities' results for a given element set.  I can export this result to h3d files after each iteration (The files with name of ..._s1.h3d, ..._s2.h3d...) I can write a TcL script, which can query the SED values of the given element set, from each relevant h3d file of the subcases. After that, I import them in python to make calulations with them, then a single number as an objective value can be exported into an excel file, for example in the A1 cell. And in the next run, I do this again, rewriting the excel file, until my objective reach its minimum. Calculations in the excel spreadsheet is not an option either, because I have a LOT of elements. (The results from the other loadcases are used for other constraints, but it is irrelevant now, because there is built-in response for that.)
Is that possible? How does Optistruct know, that my excel is ready? Can I automatically interrupt the calculations of the optimization run, until I query the results and calculate my objective with python? Is there any "banana peel" in this job?
Any comment will be appreciated.
1 - 3 of 31
