🎉Community Raffle - Win $25
Join and Win
Automator Timer Retry
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am using v14.0 of Automator and when I try to run the process below it should be running with all 3 input files but for some reason only runs the top one. When I remove the timers it runs properly but I need the timer as the reports may not be saved to the server yet. I'm still new to the Timer tool, did I set this up correctly? The Timer is set to retry every hour for at most 8 times.
Thanks,
1 - 6 of 61
    Altair Employee
    OP
    The timer is used to allow a process workflow to be retried if it fails.  It takes either a Check File, Check Cmd, or Check Input as its input, and it's output should point to a Report Export, Table Export, or Summary Export or Hub.  Have you tried pointing it back to the hub instead of the check input node?  Is there anything in the log file that is generated that might shed some more light on where it is failing?
    Altair Employee
    OP
    Putting it to the hub worked. Thanks Chris
    Altair Employee
    OP
    Hello, I am also new to Automator and found your post very helpful.
    I have been trying to create a process where I only get alerted a single time after a retry timer fails.  It will be normal for the retry to occur a few times but I want to be notified if it finally doesn't work.
    I have gotten this to work with the process flow below and thought it might be helpful to others trying to figure out how to do this.
    Altair Employee
    OP
    Timer.pngHub.pngcheck timer.pngDistribution On Failure.pngDistribution On Success.png
    Altair Employee
    OP
    Also, this might be helpful to those trying to figure out how to use API.GetEvents()
    I am reposting the vb code in the sample process above here as text for easier reading
    'Cause Error - this script serves to simulate a failure in your process
    'Pause for a second to make log timing easier to determine
    System.Threading.Thread.CurrentThread.Sleep(1000)
    'leave all code below commented to simulate a success on first run
    'uncomment just this line of code to force a complete fail simulating retry limit reached failure
    'Throw New Exception("intentional error")
    'uncomment this code to simulate a retry success after initial failure
    'If Not API.HasRuntimeFieldValue("HasRun") Then
    'API.AddRuntimeFieldValue("HasRun", "True")
    'Throw New Exception ("First Time through script - intentional error")
    'End If
    'check timer - this code reads the events from a timer named "Timer" in your process
    'When the timer has reached it's last retry it will throw an error so that you can control flow from this script
    'to execute just once after the timer has failed
    'Reads Events from Timer
    Dim listOfEvents As List (Of Datawatch.Services.DataPump.Common.Scripting.ProcessLogItemApiEvent) = API.GetEvents("Timer")
    API.AddEvent("FirstScript Has " & listOfEvents.Count & " Events")
    For i as Integer = 0 to listOfEvents.Count-1
    If listOfEvents(i).Message.Contains("Retry will occur at most 0 times") Then
    Throw New Exception("Retry Failure")
    End If
    Next i
    Altair Employee
    OP
    'End If
    End If
    Next i
    Sorry, this line should be corrected to make it a little more clear.
    API.AddEvent("Timer Has " & listOfEvents.Count & " Events")
