Hi,
Is there any way to create a model in Monarch Classic using source data from an Excel Work Sheet to run as a model in Data Prep Studio? I have tried this several times using a simple model, and it the past have been able to drag the model into Data Prep Studio (when a model was created for .csv files). However, when I try this I receive the error message:
“The following Monarch Files failed to import:
[1]
File: *************.dmod
Error: Content of this model file is not supported in Data Prep Studio”
Are Excel files not supported? I know that a change list in DPS is probably the next option, but I need to automate this process as much as possible.
My ultimate goal is to save several Monarch Models in DPS as a Workspace, on which excel files can be dragged onto to apply the changes, rather than creating lots of change lists.
Thanks in advance for any help!
