Auto save
Answers
Maybe:
0 -
Hello,
thank you. how can i get this script.
Sandeep
0 -
Script is always downloadable on this page. The link is just below of picture.
0 -
Hi Sandeep,
For autosave option, please follow this link: http://www.altairuniversity.com/wp-content/uploads/2017/01/AutoSave.pdf
0 -
Altair Forum User said:
Hi Sandeep,
Hi,
Is there any function that Hypermesh just save file without geometry data?
so autosave will not be lag when process big file.
I thought about export solver deck when autosave, but it still costs much time with big file, because of writing as text data
So I've been searching a function to write binary data...
0 -
Hi Tinh,
Autosave saves all the details in .hm file.
Can you try with entity state browser?. The export/do not export option in entity state browser determines whether entities are to be exported or not. Using this, user can export only the required data.
0 -
Hi Sir, I found a way
entity state browser control import/export but as I say, exporting to text data still cost much time
I found in HM14 a function named *filewriteentities that can save binary FEM data only
the only an inconvenience that I have to organize FEM and GEOM data in different comps which are stored in different modules, too
another function, *filewritecomponentgeometry can save a component to hm file. but it is save only GEOM
hoping there is a function named *filewritecomponentfem ... in future versions
0 -
Hi Sandeep,
Hello George,
i followed the procedure as given in pdf. but it is unable to on autosave. no one popup window opening.
is it working for HM13 vesrion?
0 -
Hi Sandeep,
Its working for 13 version.
Type as in the pdf and please send a screenshot of the command window
0 -
Hi Sandeep,
pls see snapshot below
0 -
Hi Sandeep,
After source, put a space and provide the path directory and try.
That is source {C:\Program Files\Altair\13.0\hm\scripts\autosave.tcl}
0 -
Hi Sandeep,
Hello sir,
now its working fine. thank you so much...
one more doubt regarding the same.
it saves extension as .hmbackup, if unfortunately file corrupted i can open the .hmbackup & can work on it.
but while working on .hmbackup file i am unable to save the file manually. is it again automatically saving the iterations or i have to save .hm file separately ?
sandeep
0 -
Hi Sandeep,
You will have to save the file separately.
0 -
Hello Sir,
the zip file contains extension .tbc. & it is not taking this format.
.tcl can be open i think in keyboard settings? pls help
Sandeep
0 -
ok sir i will try this.
regarding autosave script. one thing i want to share. we can change extension .hmbackup to .hm & its working fine
can refer below image.
0
