In many command, like *createmark or *createentity, we should an entity type. In general, the often used entity types are elems, nodes. Where to find all the valid entity types for this command?From the help manual or hypermesh gui?
Hi Roy,
You can find it in HyperMesh reference guide or search it in Altair Connect.
https://connect.altair.com/CP/kb-view.html?kb=146854
