Altair RISE
Nominate Yourself Now!
Auto save
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I am having below questions.
1) Is there any shortcut key to save HM?
2) Is there any process or any script to auto saving HM file? that could help to save the file at regular interval.
Thanks in advance,
Sandeep
1 - 16 of 161
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Maybe:
    Altair Employee
    OP
    Hello,
    thank you. how can i get this script.
    Sandeep
    Script is always downloadable on this page. The link is just below of picture.
    Altair Employee
    OP
    Hi Sandeep,
    For autosave option, please follow this link: http://www.altairuniversity.com/wp-content/uploads/2017/01/AutoSave.pdf
    User: "tinh"
    Updated by tinh
    Hi Sandeep,
    Hi,
    Is there any function that Hypermesh just save file without geometry data?
    so autosave will not be lag when process big file.
    I thought about export solver deck when autosave, but it still costs much time with big file, because of writing as text data
    So I've been searching a function to write binary data...
    Altair Employee
    OP
    Hi Tinh,
    Autosave saves all the details in .hm file.
    Can you try with entity state browser?. The export/do not export option in entity state browser determines whether entities are to be exported or not. Using this, user can export only the required data.
    User: "tinh"
    Updated by tinh
    Hi Sir, I found a way
    entity state browser control import/export but as I say, exporting to text data still cost much time
    I found in HM14 a function named *filewriteentities that can save binary FEM data only
    the only an inconvenience that I have to organize FEM and GEOM data in different comps which are stored in different modules, too
    another function, *filewritecomponentgeometry can save a component to hm file. but it is save only GEOM
    hoping there is a function named *filewritecomponentfem ... in future versions
    Altair Employee
    OP
    Hi Sandeep,
    Hello George,
    i followed the procedure as given in pdf. but it is unable to on autosave. no one popup window opening.
    is it working for HM13 vesrion?
    Altair Employee
    OP
    Hi Sandeep,
    Its working for 13 version.
    Type as in the pdf and please send a screenshot of the command window
    Altair Employee
    OP
    Hi Sandeep,
    pls see snapshot below
    Altair Employee
    OP
    Hi Sandeep,
    After source, put a space and provide the path directory and try.
    That is source {C:\Program Files\Altair\13.0\hm\scripts\autosave.tcl}
    Altair Employee
    OP
    Hi Sandeep,
    Hello sir,
    now its working fine. thank you so much...
    one more doubt regarding the same.
    it saves extension as  .hmbackup, if unfortunately file corrupted i can open the .hmbackup & can work on it.
    but while working on .hmbackup file i am unable to save the file manually. is it again automatically saving the iterations or i have to save .hm file separately ?
    sandeep
    Altair Employee
    OP
    Hi Sandeep,
    You will have to save the file separately.
    Altair Employee
    OP
    Hello Sir,
    the zip file contains extension .tbc. & it is not taking this format.
     .tcl can be open i think in keyboard settings? pls help
    Sandeep
    Altair Employee
    OP
    Hi Sandeep,
    To create a shortcut for saving as .hm file in HyperMesh use  eval [[. cget -menu].file invoke 2] command in the keyboard shortcut menu.
    Altair Employee
    OP
    Hi Sandeep,
    ok sir i will try this.
    regarding autosave script. one thing i want to share. we can change extension .hmbackup to .hm & its working fine
