Fan Component
1 - 2 of
21
Thanks acupro, I used stagnation pressure as inlet boundary condition. But my pressure rise isn't matching volumetric flowrate.
The pressure rise is 64.07Pa but the Volumetric Flow rate is only (5.562m/s*0.00383m² or 4.237m/s*0.005024m²) 0.00213m³/h which is lesser than the appropriate value in the performance curve.
Requesting your help in figuring this out.
This tutorial reviews a fan component - for a fan in a duct.
https://2022.help.altair.com/2022.2/hwcfdsolvers/acusolve/topics/tutorials/acu/acu_5101_intro_cfd_r.htm#acu_5100_intro_cfd_r
That uses a volumetric flow rate at the inlet. In your case, you probably want to use a stagnation/total pressure inflow type. Then the flow rate and pressure rise will be computed by the solver.
