🎉Community Raffle - Win $25
Join and Win
plotting from .csv or .txt file
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi
I got a problem with plotting using external .csv and .txt file. Currently I can only get the Y axis right, but X axis just like a automatic generated number order. (see attachment) I think I have run through all the options from Hyperview, but just can not make it.
Is it possible to change to what it is in the attached file for X axis?
Many thanks.
<?xml version="1.0" encoding="UTF-8"?>post-7386-0-56516900-1372223627_thumb.jp
1 - 2 of 21
    Altair Employee
    OP
    Hi Thomas,
    it works perfect with your attached data file. See picture below...
    It is really nice to attach datas, so i can check it very fast.
    Try this way:
    1. load your file
    2. select for x-type -> unknown; x-request -> Block 1; x component -> Column 1
    3. select for y-type -> unknown; y-request -> Block 1; y component -> Column 2
    4. preview or apply
    Hopefully it works...
    Best regards,
    Mario
    <?xml version="1.0" encoding="UTF-8"?>post-817-0-08797400-1372225103_thumb.jpg
    Altair Employee
    OP
    thank you Mario. Your answer is great and help me a lot.
