Force vs Displacement Curve
Hello George,
Thanks for your eply. The error with the values is still persisting. I had choosen displacemnt vs time curve as x axis and force vs time as y axis.. It still shows me lower values for the force. When i do it dispalcement vs force with displacemnt as y axis and force as x axis. It plots the correct values for the force.
1 - 3 of
31
Please refer attached cross plot video for Force Vs Disp plot.
When i transfer through export, why are the values being showed in one column of excel sheet? is it normal?
