Retain User Comments In NASTRAN .bdf File
Hey everyone,
I have a .bdf file (the solver deck file required for NASTRAN). Hypermesh creates this file by the export process.
My work requires that I edit the .bdf text, but also use the graphical features of Hypermesh.
I would like to find a way of retaining user-added comments in the .bdf.
Let me explain:
1. Create mesh
2. Export as .bdf
3. Comment the .bdf file appropriately
-BUT-
4. When I re-import to HM and export, my comments are removed.
Is there a way to keep them? Hypermesh will keep comments that are attached to material properties (for example, if I add a comment to a MAT1 card, they will stay with import/export)
Thanks for any help!
Yes, you can add comments from inside Hypermesh and eventually export them to BDF output.
However, I don't think you can import comments with your BDF file.
Thanks for you replies guys, I'll look at those options!
The files I am editing have large revision comments. I need to keep them when I import and export:
i.e.
' Date, Revision Number, comments about revision '
etc.
Thanks again for you replies, if you think of other options, let me know!
I noticed that! /emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' /> I was wondering why this was. Other comments (if I comment a range of GRIDS) don't stay. I had a MAT1 card that I commented, and the comment stayed, but my comments above my GRIDS were deleted.
Is there a way to 'trick' HM to keep the comments on the GRIDS?
http://onlinecasinouse.com/# casino bonus codes casino games casino real money
Hi
in hm gui, try editting card of material and setting option for user comment as 'show in export'
so you can add comments in card editor then export
