🎉Community Raffle - Win $25
Join and Win
Spring with different stiffness in compession and tension
User: "mpvnaresh"
Altair Community Member
Updated by mpvnaresh
Hi
I am working on Direct Transient response analysis.
I am modeling the shock isolator as a bush. But the problem is the stiffness value in one direction , compression stiffness and tension stiffness are not same.
Can any one help in modeling such a bush.
1 - 6 of 61
    User: "Tommy_21858"
    Updated by Tommy_21858
    For this you need an PBUSHT card with TABLED1 for your damper direction. In the table you can define the stiffness depending on the elongation.
    User: "mpvnaresh"
    OP
    Hi ..Thanks for response.
    I have only two stiffness values (K compression, K tension) I have no deflection vs Stiffness data.
    Is there any way i can do this.
    User: "Tommy_21858"
    You can also create a curve / table (force vs deflection) with two values. For example:
     TABLED1        5  LINEAR  LINEAR +           -1.0  -100.0    -0.1  -100.0     0.0     0.0     0.1    100. $--1---][--2---][--3---][--4---][--5---][--6---][--7---][--8---][--9---] +            1.0    100.    ENDT
    User: "mpvnaresh"
    OP
    Thank you
    User: "mpvnaresh"
    OP
    Hi
    I am using PBUSHT in DTRAN solution . This is not working for me.
    can any body help in this ( Is PBUSHT compatible with DTRAN ? )
    The data i have is attached . Please help me in modelling the same.
    User: "Tommy_21858"
    In my opinion pbusht in DTRAN should work. But I haven't use it together until now. Maybe you can add your table entries or model?
    Best regards
