Effect of RBE3s on stiffness
User: "exx077"
Altair Community Member
Updated by exx077
Hello,
If I am to put RBE3 in a hole (with no force or constraint attached to the dependant node) will this imply any stiffness to the voids outer surface where the independent nodes are?
Or does the hole just remain as it would if it was a void with nothing in it?
What type of 1D element could be used to provide a defined stiffness to the outer surface of a hole?
Thank you in advance
1 - 12 of 121
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    RBE3 element has NO stiffness.
    If you wan to add stiffness, try rod,bar, beam,...
    User: "tinh"
    Updated by tinh
    are you continuing this topic?
    https://forum.altairhyperworks.com/index.php?/topic/23230-contraining-a-hole-as-a-void-that-will-not-expeirence-deformation/
    I suggest you try modeling a shaft and make it contact tied with hole of bracket
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    If you have particular stiffness values you want the hole to have, you can also try using GAP elements or CBUSH.
    User: "exx077"
    OP
    Updated by exx077
    Hi all,
    Thank you for your responses. This has helped with my understanding.
    If I am to try to model a bearing I will use this method.
    I do have a radial stiffness value. I will try and use these elements and input the stiffness values. Is it possible to use CBUSH or GAP elements as a spider that is constrained in the middle (like a RBE2 or 3 element spider)?
    Thanks
    User: "tinh"
    Updated by tinh
    try it! you can use cbush spider but i think no need to constraint its center
    User: "exx077"
    OP
    Updated by exx077
    Hi @tinh,
    I did try both methods.
    The panels for spring and bar elements do not have an option to create a 'calculated node' from nodes selected on a surrounding face - like there is with the rigid and RBE3 element panels.
    Hence, my question was, is it possible and if so, how?
    Thank you
    User: "tinh"
    Updated by tinh
    Just create the center nodes and bind it to hole by spring/bar
    As @tinh said create a center node.
    You can do it by Geom>>distance.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.f6d18647a31df7347172674b4681ac1d.png
    Select three nodes of circle and click on circle center
    User: "exx077"
    OP
    Updated by exx077
    Hello,
    Thank you for your responses. I will create the centre node using this method.
    However, is it possible to select all the surface nodes on the inner surface of the hole in one go?
    As from what I can tell I will have to select each node individually and connect this to the centre node to create a spider.
    Thank you
    User: "tinh"
    Updated by tinh
    there is a tcl script that changes rbe spider to bar/spring spider. I remember someone asked for it on this forum.please search it
    User: "exx077"
    OP
    Updated by exx077
    Thanks @Tinh,
    I came across this, but it seems to just be available to Altair clients - which I am not.
    https://forum.altairhyperworks.com/index.php?/topic/13205-hyperworks-script-exchange/
    Is there a better/easier way to add a defined amount of (radial) stiffness to a cylindrical hole?
    Thank you
    User: "tinh"
    Updated by tinh
    make a cylindrical system, assign it as disp system of the nodes and constraint their 1st dofs (r)
