🎉Community Raffle - Win $25
Join and Win
Effect of RBE3s on stiffness
exx077User: "exx077"
Altair Community Member
Updated by exx077
Hello,
If I am to put RBE3 in a hole (with no force or constraint attached to the dependant node) will this imply any stiffness to the voids outer surface where the independent nodes are?
Or does the hole just remain as it would if it was a void with nothing in it?
What type of 1D element could be used to provide a defined stiffness to the outer surface of a hole?
Thank you in advance
1 - 12 of 121
