Can not find "BCs manager " in Hypermesh 2020
Hello,
I'm doing impact simulation with Radioss setup in Hypermesh.
But i can not find 'BCs manage' tool to setup.
Anyone using Hypermesh 2020 version here can help me ?
Thanks advanced.
THanks Koushik,
I found 'Boundary conditions' tool form Solver Brower.
I doing create Fix node around 'Plate ' components :
First time I create GRNOD/NODE then apply to Boundary conditios / BCS.
But it doesn't get enough node that i have assign in 'set1' (As bellow picture)
So could you tell me what about that ?
this is just visual.
In order to avoid the GUI to be overloaded, this is how loads on sets are being displayed now.
You can always RMB, then, 'review' for getting the full view of nodes that are referenced.
Hi Adriano,
I can't assign 'Plate ' component in Contact Type7 step.
I think something wrong in create Fix node in Plate step.
Could you help me check file attached
Thanks advanced.
does your component have 'Part' Card Image associated to it?
Many thanks Adriano,
I have do it
Hi,
The BCs Manager in Radioss is completely removed in HyperWorks 2020.
Now, the loads can be easily created and handled from Solver Browser as shown in the image below:
