tcl command for nodes on a surface?
Hi all,
I have a component which consists solid geometry.
I have meshed it by creating a tcl script (only a couple of commands needed for this).
Now I have to apply constraints and loads on some surfaces of this solid (which is now meshed).
I am searching for a tcl command which can give me all the nodes on the surfaces of this meshed component.
I know the commands which are used to get nodes from a component, but there exists no such information about how to get the same from surfaces!
Kindly advise some hints/methods for this purpose.
Best regards,
Mubeen.
Hi,
you try *createmark ”by surface”
and look up in help about this command with many powerful options
