🎉Community Raffle - Win $25
Join and Win
Optistruct Result analysis (NL Geom)
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I did a Non linear Analysis using Optistruct.....its basically 2 components having contact pair. In the lower clip region, i apply different forces with 1N,100N & 1000N. while the upper clip is constraint.
In all the cases,(with different forces) i am getting the similar results.....in 'displacements and element stresses'. can you suggest what could be the reason for this ?
Stress : 0.4467
Displacement : 0.05166  for all the cases, which seems very unrealistic.
Please see the attached picture.
thanks.
<?xml version="1.0" encoding="UTF-8"?>post-36170-0-03749700-1434467283_thumb.j
<?xml version="1.0" encoding="UTF-8"?>post-36170-0-61170400-1434467291_thumb.j
<?xml version="1.0" encoding="UTF-8"?>post-36170-0-69419500-1434467391_thumb.j
1 - 4 of 41
