Elements control over automatic Penetration / Intersection fix
Hi All,
I have 2 components A & B where I have found penetrations. when I use Automatic Penetration fix, the elements of component B are getting adjusted. The problem is I want elements of B to be unchanged. Can I have control over one component alone (in my case on A) so that elements of only that component can be reorganised?
1 - 5 of
51
Hi Ushay,
Which user profile are you using?.
In penetration tool, user can select the elements to be moved manually and can move.
