Elements control over automatic Penetration / Intersection fix
Ushay
Ushay Altair Community Member
edited October 2020 in Community Q&A
Hi All,
I have 2 components A & B where I have found penetrations. when I use Automatic Penetration fix, the elements of component B are getting adjusted. The problem is I want elements of B to be unchanged. Can I have control over one component alone (in my case on A) so that elements of only that component can be reorganised?
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited September 2017
    Hi Ushay,
    Which user profile are you using?.
    In penetration tool, user can select the elements to be moved manually and can move.
  • Ushay
    Hi George, I am using RADIOSS. I would like to perform an Automatic fix since I have many elements. Will I be able to have such control in Automatic fix option?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    HI Ushay,
    In RADIOSS user profile you can easily fix one component and move other for fixing penetrations, but using manual methods.
    Please go through the below post which shows the same operation.
    In HyperCrash you can do this operation in Automatic fix option.
  • Ushay
    thanks George
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2019
    hi all
    I am using HM14. i want to hide self penetration for an assembly. How can i hide ?
    For my assembly more self penetrations are coming which will take more take if i check manually.
Welcome!
Welcome!
