🎉Community Raffle - Win $25
Join and Win
What is different b/w using Contact Surface to define contact group v.s create SET_ELEM set?
User: "alpha_21885"
Altair Community Member
Updated by alpha_21885
Hi,
To define contact pair (group) in O.S I often create contact surface then create contact group. It takes me a lot of time to choose contact surface for some part.
There is another option, I create set (SET_ELEMENT), then point to elements (by collector) to select all. It is a bit faster because I can script.
However, I am newbie and not sure which method is better about computation speed or accuracy?
Could you advise?
1 - 3 of 31
