Altair RISE
Nominate Yourself Now!
Script for Delete Empty
hello,
i am new to make scripts. i am trying to do a script to delete empty assemblies and sub assemblies in one action. i need a loop format of script to do this. but i dont know the structure. please help me out.
1 - 12 of 121
    Will tell the logic, try to do yourself and let us know if you still need help.
    EntityPreviewEmpty will check the empty assemblies in your model. Use this API and while loop to check and delete the empty assemblies
    use deletemark to delete the entities.
    Check this to understand how while loop works https://www.tutorialspoint.com/tcl-tk/tcl_while_loop.htm
    Thank you for your reply sir.
    *EntityPreviewEmpty 1
    set d [hm_getmarkentitytypes 1];
    hm_createmark 1 $d;
    #while loop execution
    while { $d == 1 } {
       puts $d
       incr d
    *deletemark $d
    i have tried with my knowledge, please let me know your corrections.
    thanks in advance.
    tinhUser: "tinh"
    Altair Community Member
    Updated by tinh
    While {*EntityPreview.. ; hm_marklength assems 1}  {*deletemark assems 1}
    QuyNguyenDaiUser: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Here's the script found on Altair site:
     #--------------------------------------------------------------------------------------------  #This script deletes assemblies recursively, optionally comps will be deleted # steenbock@altair.de, 20141008 # V. 01 #-------------------------------------------------------------------------------------------- proc run {} {  	*clearmarkall 1 	*createmarkpanel assems 1 'select assems 2 delete' 	 	#delete comps or not 	set answer [tk_dialog .owd 'Selected Assems: [hm_getmark assems 1]' 'Delete Components in Assems?' 'question' 0 'No' 'Yes' 'Cancel'] 	switch $answer { 		0 {set delComps 0} 		1 {set delComps 1} 		2 {tk_messageBox -message 'Misson abort!' -type ok -icon warning; return;} 	} 		 	# loop whole assem tree 	foreach ass [hm_getmark assems 1] { 		deleteSubAssems $ass $delComps 	} 	*clearmarkall 1 }  proc deleteSubAssems {assem delComps} { 	set output 1 	if {[hm_entityinfo exist assem $assem] == 1} { 		set sub_ass [hm_getentityarray assemblies $assem assemblies]  		# part where comps will be deleted 		if {$delComps != 0} { 			set sub_comps [hm_getentityarray assemblies $assem components] 			if {[llength $sub_comps] > 0} { 				eval *createmark comps 1 $sub_comps 				if {$output ==1} {puts '\t\tdelete comps: $sub_comps'} 				*deletemark comps 1 			} 		} 		# delete assem 		*createmark assems 1 $assem 		if {$output==1} {puts '\tdelete assem id=$assem ([hm_getentityvalue assemblies $assem name 1])'} 		*deletemark assems 1  		if {[llength $sub_ass] > 0} { 			foreach a $sub_ass { 				deleteSubAssems $a $delComps 			} 		} 	} } #----------------------------------------------- run
    Thanks for your thoughts...
    this script is not working
    llyle_20499User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    For future reference, I was able to do using below:
     	set str_flag 1 	while {$str_flag} { 		*EntityPreviewEmpty assem 1 		if {[hm_marklength assem 1]} { 			*deletemark assems 1 		} else { 			set str_flag 0; 		} 	}
    I am run this script but error is entity is not found why?
    hm_createmark 1 $d;
    *deletemark $d
    this is also not work
    Hi , If I want to delete all load collectors, load step along with empty and unused entity .which loop/command  I need to use or command.
    currently, I ma using below command for deleting empty comp.
    proc cleanModel {n type} {
     *EntityPreview$n $type 1
     while {[hm_marklength $type 1] != 0} {
      *deletemark $type 1
    cleanModel Empty comps
    cleanModel Unused props
    cleanModel Unused mats
    cleanModel Empty sets
    cleanModel Empty assembly
    Yesvanth RUser: "Yesvanth R"
    Updated by Yesvanth R
    you can use the following script
    to delete empty components
    *createmark comps 1 "all"
    hm_getunusedoremptyentities mode=empty type=comps inputmark=1 outputmark=2
    *deletemark comps 2
    to delete unused property
    *createmark prop 1 "all"
    hm_getunusedoremptyentities mode=unused type=prop inputmark=1 outputmark=2
    *deletemark prop 2
    to delete unused assemblies
    createmark assy 1 "all"
    hm_getunusedoremptyentities mode=empty type=assy inputmark=1 outputmark=2
    *deletemark assy 2
