creating one component as one part
I am trying to combine several part (surface and solid) in to one part. How can I do that?
After I move several component to one component and exporting it as STEP file and opening it in different software , I do see that those parts exist (i.e. they are not merge as one part). How can I fix this issue?
Rahul, exporting with displayed option didn't work (same as exporting all) . Th question is how to convert an assembly (surface and solid) into one solid model
did you tried solid edit merge option to make one part.
I tried that option but it says selected solids do not share surface. However, when I look at by 3d Topo I see all green lines. I don't know how I can fix this issue
If your model have both solid and surfaces then delete all surfaces & try to use merge option.
I tried that option but it says none of selected solid share edges.
Thanks for the update. I believe it worked fine.
Hyperworks is NOT CAD Software!
