How to set up a Shock (half sine shock pulse) and Sinus Vibration Test?
User: "Wiz211"
Altair Community Member
Updated by Wiz211
Hello,
Currently I am working on a structural analysis. I already meshed the model, finished the Model Checks and some Analysis (Modal, Quasi-Static and Frequency Response).
But now I am stuck on the next analysis types.
I need to set up a :
Shock Test
  • Amplitude: 50 g
  • Type of Excitation: Half Sinus
  • Pulse Duration: 10 ms
  • Nr. of Shocks: 1 (in all + - directions)
Sinus Vibration
  • Amplitude: 4.5 g
  • Type of Excitation: Sinus
  • Frequency: 0 - 100 Hz
I would like to know what Load Collectors, Analysis Type (Load Step) and Control Cards I Need to start the simulations.
I appreciate every advise :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
1 - 4 of 41
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    This is dynamic analysis (time domain)problem.You could use TLOAD2 card to define the equation
    User: "Swapnil888"
    Updated by Swapnil888
    Sir for shock test please guide in terms of load step
    User: "Mani kumar_21615"
    Updated by Mani kumar_21615
    Shock test:
    1.constraint All DOF at your desired region with load type SPC
    2.Excite your body with acceleration with load type :SPCD(if excitation in y direction give y=500,remove all dof)
    3.Create table d1 card with sine graph
    4.create tload spcd and tabled1 with load type : accelartion
    5.create tstep
    User: "Enrico Corallini"
    Updated by Enrico Corallini
    Hi,
    Is it possible to set up a similar simulation in Simlab?
    Thank you
    Enrico Corallini
