🎉Community Raffle - Win $25
Join and Win
Acusolve CHT Result Export
User: "Akhilesh Katipally"
New Altair Community Member
Updated by unknown
Hello, I am running a Laminar CHT analysis (Pipe flow). How do I select the outputs? Acusolve is not exporting the surface film coefficient (HTC) at the interface between the solid and the fluid domains. It outputs the temperature, pressure and velocities.
On a side note, I am using HM 2017.2 and how to do set up a CHT analysis in HM? Specifically, I wanted to know how to setup the interface. Looking at the tutorials, I setup 2 interfaces (duplicate elements). I defined one interface as a wall and the other as an interface. It did not run. Anything that I am missing?
Thanks,
AK.
