Rigid projectile impact on sheet metal
Hello everyone,
I am trying to do a simulation of a rigid projectile (here a ball...) impact on sheet metal (or other material). I have already done an experimental test with an INSTRON Drop Weight Testers. For information, it is my first crash simulation.
The goal is to compare the results between simulation and experimental test. In a further point, it will be to analyse the rupture phenomenon.
I have created a ball and a sheet that I have meshed and done everything about the parameters but... I have got two major errors :
- error in solid property : 226 - 312
- error in initial penetration in interface : 612
I have tried to search some information and correct the mistakes but... still not ok...
Someone can help me ? I will really appreciate your advice !
Kind regards,
Pegase33
Hi,
there are a number of ways to find master node ID:
https://community.altair.com/community?id=community_question&sys_id=4c5644b61b2bd0908017dc61ec4bcbbc
Hello everyone,
The simulation for the steel is conform to the experimentation... However, it is not the case for the aluminium... (With my Drop Weight Tester, I have 10 mm of displacement and the simulation gives 5 mm)...
Have you got any ideas ?
Kind regards
Hi,
Use Tools>Model Checker>RadiossBlock to find modeling errors.
https://insider.altairhyperworks.com/wp-content/uploads/2017/09/T-T-1248-HyperMesh-Model-Checker.pdf
