Hi All,
Please Help with the answers for frequency response analysis of impeller assembly.
In the image you can see that impeller is directly coupled to the motor. Motor is fixed to the sheet metal structure in green. The edges of sheet metal bolted to main frame.
1. My doubt is how to do the FRF for rotating structures ?
2. Generally we apply unit force as excitation for a range of frequency in case of structures, what about rotating structures ?
3. How to specify the excitation for rotating structure?
4. Is it possible to give rotary excitation ?
5. what should be my excitation location and response location ?
