Topography optimization of frequency using stacked plies
Hello,
I'm having troubles setting up a topography optimization using plies. The model is a heatshield with 3 different layers(thickness) and Im using PCOMPP card as property to them.
I believe that the optimization settings are correct, because I had already used the same settings in a previous single layer model and it went ok.
But when I try using stacked layers something goes wrong. Im getting the following error:
*** ERROR # 79 ***
DTPG data does not create any DVGRID data.
There are no free referenced GRIDs.
There may be no elements associated with the PSHELL data.
LOAD or BOTH may be specified and all grids may be loaded.
BC, SPC, or BOTH may be specified and all grids may be SPCed.
Any thoughts??
If there is some paper relating modal+plies+optimization that can be provided I'll appreciate.
Thanks in advance.
It worked! I saw that the problem was in the 'entity type' of Topography design variable right? As soon as it was changed to STACK the optimization runs properly.
Thanks Prakash, problem solved.
Correct /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Hi @mdrehmer
Is it possible to share the model file with us?
Please use the file transfer link in my signature to share the model file
