Non-linear quasi static analysis with temperature
mabefa
mabefa Altair Community Member
edited October 2020 in Community Q&A
Hi, I'm following a tutorial of my teacher about a non-linear quasi-static analysis in which there's a temperature gradient. He is using the 2013 version of HM but I have the 2017 one and so I think there is a problem in setting the loadstep. In fact in the loadstep of the 2013 version appears the keyword TEMP in which I can set the load collector for temperature, but in the 2017 version this Keyword misses, so how can I set the temperature load collector in the linear static analysis?
<?xml version="1.0" encoding="UTF-8"?>image.png.5c4df37d4a590d46d25aedf4e841e497.png
Answers
  • Pranav Hari
    Pranav Hari Altair Community Member
    edited April 2019
    Hi mabefa
    After creating the load step, click on 'edit' and then you have an option for entering temp load collector.
  • mabefa
    edited April 2019
    Ok, I tried and it actually worked. Thanks a lot for the answer.
Welcome!
Welcome!
