Altair RISE
Nominate Yourself Now!
Distance between two nodes
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I need to access the distance between two nodes using a tcl file.
How can I do it ?
Thanks
1 - 5 of 51
    User: "Beta"
    New Altair Community Member
    Updated by Beta
    Hi Benoit,
    you can use the command hm_getdistance to do that
    Altair Employee
    OP
    Hello Toan,
    Thanks for your help.
    User: "tinh"
    Updated by tinh
    Hi
    It is hm command
    Replace ( and ) and , by space to get tcl commands
    If you are searching for closest node on surf, use hm_measureshortestdistance, do not use loops which will slow down program
    Altair Employee
    OP
    Hi Benoit,
    Hello
    When I use the command hm_getdistance HyperMesh returns 4 values and I need to put the fist one in a variable distance.
    (Documents) 4 % hm_getdistance nodes 3723 5317 0 0
    68.91864249631689 41.6426000000006 54.90046920132 -1.2694999999999936
    How can I isolate the first value in a variable?
    thanks
    User: "Beta"
    Updated by Beta
    Hi Benoit,
    For what you want, you need to use TCL command: lindex.
    this command is used to return the element from a list.
    Try the following code.
    Cheers
     set distance_list [hm_getdistance nodes 3723 5317 0]. set distance [lindex $distance_list 0]
