Altair RISE
Nominate Yourself Now!
How to set Temperature as load in Thermal Analysis?
User: "Pouyan"
Altair Community Member
Updated by Pouyan
Hello Friends,
I want to perform a basic thermal analysis in Hyperworks: Assume we have a cube with fixed temperature on two side of it, run analysis and get temperature distribution within the cube. The question is How can I add Temperature as load?
I am aware that I can use heat convection or heat flux, but I want to use temperature as load.
Best,
Pouyan
1 - 14 of 141
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi,
    You can apply temperature using temperature panel in Analysis page.
    Assuming you are trying to run a linear static analysis with temperature as load, here is what you have to do:
    1) Create a loadstep with Linear static as type
    2) Add SPCs if you have any but leave load blank
    3) Click EDIT if you are using Loadstep panel or scroll down in Entity editor to find TEMP_LOAD
    4) Check this and add the temperature load here.
    See the attached image for more information
    User: "Pouyan"
    OP
    Updated by Pouyan
    Dear Prakash,
    Thank you for your response. But, I can't find THEMP_LOAD under 'subcase option'. (I am using HyperMesh v14.0)
    Thanks,
    Pouyan
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.22588ad00c21e79976ab2872cac82a8e.png
    Altair Employee
    Hi,
    Use Temp(loadcol). Reference temperature load collector here and please let me know the results
    User: "Pouyan"
    OP
    Updated by Pouyan
    I tried that, but it does not work as well. It does not show Thermal distribution within the component. it is just stress analysis.
    User: "Pouyan"
    OP
    Updated by Pouyan
    I attached the simple model I am talking about. Can you tell me where is the problem?
    Thanks
    Altair Employee
    Hi @Pouyan
    I will check and will get back to you.
    Altair Employee
    Hi @Pouyan
    Please find the modified deck.
    One side of the box has 80 temperature and the other is 40.
    Use SPC and card edit the spc and enter temperature value in the field D
    User: "Pouyan"
    OP
    Updated by Pouyan
    Hi Prakash,
    Thank you for your help.
    Best,
    Pouyan
    Altair Employee
    I hope attached file helps.
    Please let me know if you need any help
    Altair Employee
    Dear Prakash , can you please share that HM file again. Am not able to access that HM file you shared.
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Could you please let us know the problem you are facing?We don't have the  backup of shared hm file.
    User: "Dp12"
    Updated by Dp12
    Hi Rahul,
    what is TREF in MAT1 card.
    I am simulating exhaust manifold and having temperature distribution over all nodes.
    I have run the linear static analysis but stresses are very very high >500MPa.
    When I am useing Tref =400 deg C, then stresses are low.
    My average temp over exhaust manifold nodes is 500deg C.
    Please comment.
    Thanks in advance.
    Regards,
    Dheeraj
    TREF: Reference temperature for thermal loading.
    User: "tt tt"
    Updated by tt tt
    Hi @Pouyan
    i, i have question for you
    in the fem content, wht can't use "temp" control card?
    what is the between "spc" and "temp" different
    do you have "temp" control card example fem
    thanks, a lot!
