🎉Community Raffle - Win $25
Join and Win
Error: *setvalue
User: "Halil"
Altair Community Member
Updated by Halil
Hi,
I am running tcl with batch mode from Python and everything works fine. However, when I convert python script into .exe file and run the file I got an error. I checked library given below and the file exist in the path given below.
"TclInterpInit: couldn't load library "C:Program Files/Altair/2021.2/hwdesktop/hw/rData/bin/win64/rDataTcl.dll": this library or a dependent library could not be found in library path"
Error: *setvalue: Could not modfiy value for dataname/attribute: init 0
     while executing
"*setvalue results id=$resultid init=1"
Can anyone help?
Thank you.
1 - 2 of 21
    User: "Rishabh"
    Altair Employee
    Updated by Rishabh
    Hello Halil
    This path "C:Program Files/Altair/2021.2/hwdesktop/hw/rData/bin/win64/rDataTcl.dll" seems to be incorrect. It's missing a backslash after C: . The correct path should be        C:/Program Files/Altair/2021.2/hwdesktop/hw/rData/bin/win64/rDataTcl.dll.
    Can you check code if this path is hard coded ?
    User: "Halil"
    OP
    Updated by Halil
    Hello Rishabh,
    Thanks for the response. I only give the location of "hmbatch.exe" file and the location starts with "C:/Program Files" as you said.
    Furthermore, I solved the issue. I was using PyInstaller to convert the script into .exe file. It is most probably because of PyInstaller since when I use cx_Freeze for the conversion, everything works fine.
    Thanks anyway.
