🎉Community Raffle - Win $25
Join and Win
What's the formula for the FFT spectrum?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I want to create a 2D curve with the values of the first harmonic of TorqueElecMag(ROTOR)  to see how it changes with an I/O Parameter. Is that possible?
1 - 3 of 31
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    When you draw the curve of the torque, you can get the FFT of this curve. To do it:
    • Select the curve
    • Right click
    • Select Spectrum analysis (FFT)
    From this curve you get the first harmonic of the torque. And if you want of see the effect of I/O parameters you need to draw the FFT.
    Best regards.
    Altair Employee
    OP
    Thanks for answering..
    But I was wondering if theres a way to create a 2d curve with the first harmonic module on the Y axis and different values of an I/O parameter on the X axis.
    Right now I can do the fft spectrum separately for each value of the I/O parameter but I don't know how to do a 2d curve with the values I mentioned earlier.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    To get the first harmonic from a curve you can use this python script:
    print  Curve2d['SPECTRUM_V1'].y[0].values[0]
    Where :
    • SPECTRUM_V1' : the name of the FFT that you get from the 2D curve
    • y[0] : allows to select the amplitude
    • values[0] : allows to select the first harmonic
    To draw the curve, you can create an I/O parameter:
    b= Curve2d['SPECTRUM_V1'].y[0].values[0]
    print b
    lastInstance = VariationParameterFormula(name='First_harmonic',
                              formula=str(b))
    Hope this will help.
    Best regards.
