🎉Community Raffle - Win $25
Join and Win
xline Delete Issue
Hi everyone,
I face a problem, when I delete xline in figure. I want to create new xline when push the button, then remove the old xline. I use GUI button for this. When I push the button, it is work for two steps. However, when I push it third time, it is not remove the xline. Then, it works up to two steps. After that I face this problem again. Only one curve should remain in the figure. However, It holds ('Curve 2, Curve 4, Curve 5, Curve 7, Curve 9......') in the figure. If I write delete and create command in OML Command Window, I don't face any problem. I face a problem, when I call this command with function. Is this a bug about Compose ?
I am sharing this code in the below.
global second_line;
global sc_Value;
function button_callback(handle,callstate)
      global second_line;
      global sc_Value;
      try
           delete(second_line);
      end
      second_line=xline(get(sc_Value,'value'));
end
1 - 3 of 31
    Hi Batuhan,
    Can you share the full GUI so I can test a possible solution on my side?
    Rafael
    Hi Rafael Sánchez,
    I am sorry for the late reply. I can't share the full GUI model. However, I am sharing an example about it. You can examine it below.
    global first line
    Dialog = figure ('units', 'pixels', 'position', [0 0 410 310]...
    ,'numbertitle','off', 'name','Dialog');
    undock (Dialog);
    uiPushButton = uicontrol ('parent', Dialog, 'style', 'pushbutton'...
     ,'string','TEST'...
     ,'backgroundimage',''...
     ,'callback', 'uiPushButton_callback', 'interruptible','off'...
     ,'enable', 'on'...
     ,'units', 'normalized', 'position',[0.30 0.20 0.25 0.10]...
     ,'fontname', 'MS Shell Dlg', 'fontangle','regular', 'fontweight', 'normal', 'fontsize',8.25 ...
     ,'backgroundcolor', [246 246 246] ...
     , 'tag','','tooltipstring','','userdata',[],'visible','on');
    figure 2
    x = [0 1 2 3 4 5]
    y = [5 2 8 4 1 12]
    plot(x,y)
    function uiPushButton_callback(handle,callstate)
       global first_line
       try
           delete(first_line);
       end
       first_line = xline(rand,'color','k');
    end
    Hi Rafael Sánchez,
    global first line
    undock (Dialog);
     ,'string','TEST'...
     ,'enable', 'on'...
    figure 2
    x = [0 1 2 3 4 5]
    y = [5 2 8 4 1 12]
    plot(x,y)
       global first_line
       try
           delete(first_line);
       end
    end
    Hi Batuhan. Instead of trying to delete the line, I would toggle its visibility off. You can try something like this:
    close all, clear, clc
    Dialog = figure('units', 'pixels', 'position', [0 0 410 310]...
    undock(Dialog);
    uiPushButton = uicontrol('parent', Dialog, 'style', 'pushbutton'...
    ,'string','TEST'...
    ,'enable', 'on'...
    % Create new figure and axes
    fig = figure(2);
    ax = axes(fig, 'tag', 'Axes');
    % Mock data for figure
    x = [0 1 2 3 4 5];
    y = [5 2 8 4 1 12];
    % Plot mock data on axes
    h = plot(ax, x,y);
        % Get axes handle within this function
        ax = findobj('tag', 'Axes');
        % Get handles of lines currently present
        presentLines = get(ax, 'children');
        % Disable most recently-added line if there's more than 1
        if numel(presentLines) > 1
            lastLine = get(ax, 'children')(1);
            set(lastLine, 'visible', 'off');
        end
        % Create new line
        newLine = xline(ax, rand, 'color', 'k');
    end
    I'm attaching the script as well.
    Rafael
